Seastoke
On my controller , it’s just a switch for fan or heat with a dial for temp , I want to change it so I can switch on remotely and set temp is there a retro fit bit of kit . Cheers SS
I wanted a timer for a Webasto Air Top, had to buy the timer and an adaptor to make it fit the Air Top. l bought a new Autoterm for not much more money and put the Webasto on Ebay.On my controller , it’s just a switch for fan or heat with a dial for temp , I want to change it so I can switch on remotely and set temp is there a retro fit bit of kit . Cheers SS
While I don't have any experience with this device, it seems like the Webasto thermoconnect (TCON2) might work for you. If I recall correctly, this is the same unit our dealer recommended when we were configuring our boat. We didn't need remote control, so we didn't select this option.On my controller , it’s just a switch for fan or heat with a dial for temp , I want to change it so I can switch on remotely and set temp is there a retro fit bit of kit . Cheers SS
