oldharry
Hi all,
Last year I suffered quite severe weather helm in high winds (30+). A strong gust would round the boat up, and seemingly nothing I could do would stop it. The helm became very heavy, and spilling the main didn't seem to help once the "round up" had got going.
From this I've decided that the main needs a third, deep reef, but on top of that given some further research I think the rudder has a design flaw.
The rudder on my Corribee is a balanced spade rudder. It's balanced not far off 50%.
I've read an account of a chap fitting a newbridge skeg moulding to his boat and it doing wonders for the issues I've described, but I am reluctant to go down this route since fitting a skeg is going to be a serious project.
As such, I've decided to experiment with the rudder. I've made (am making) myself a new one with slightly more surface area (nothing excessive) and intend to mount it with a refresh bias aft, of about 2/3. I'm hoping that moving the centre of effort aft a bit will help.
What are your opinions? Am I doing the right thing?
Cheers,
Nathan
I experimented with rudder shape on my Trident a year ago, when i found the old one had a badly corroded stock. TBH I would be very surprised if the Corribee has a 50% balanced rudder. That would make her virtually impossible to handle. I increased mine to 20%, and it made her very very light on the helm and quite twitchy.
But as others have said, I do not think you are going to gain much by playing with the rudder. The problem is far more likely to be in the rig. What you describe is pretty close to classic 'overpowering' - far too much sail up for the wind strength causing you to lose control. In order to get enough sail up to keep going in light winds, the boat has a fairly large sail area for the size/weight of the hull. At 30 knots there is far too much sail up, and although crashing around lee rail under may be exciting, it is not at all efficient, and a lot of the power of the rig is effectively being wasted in just tipping the boat over. At a good angle of heel the hull creates far more drag, again slowing her down. An extra deep reef in the main will solve all this, and you may well find her going significantly faster as a pay off.
Paying atytention to tuning the rig - mast rake, luff and foot tension of the main etc - will also make significantly more difference than messing about with the rudder.
