simonthepom
New Member
I'm in the final stages of installing our watermaker (an FCI Aquamiser+). I'm not sure how to connect the fresh water (product water) to our two 300l tanks. Each tank has a separate deck filler hose that I could T-into but what happens when one tank is full? I imagine the water will just continue to flow into the other tank, but wanted to check here first.
Also, what happens when the second tank is full, any excess water doesn't have anywhere to go, which sounds like a disaster waiting to happen... How do you ensure it doesn't overflow? Is it simply a case of monitoring the flow rate and doing a few calculations as to when tanks are full? Keen to hear anyone's experience.
I've thought about adding tank gauges but this adds quite a few more €'s to the whole project, which is already quite a bit over budget...
Thanks for your advice in advance.
