sutton sailor
I am planning to make a GRP tank. I was advised to make a plug, then gel coat the plug and lay up the GRP on the outside so that the gel coat is on the inside of the tank. As this will produce a water proof tank. I had intended to make up the tank with just lay up resin and glass then coat both inside and out with epoxy resin to produce a water proof tank. However some one said to me that some grades of epoxy resin are not suitable to be used with potable water. Can the forum advise me. The tank is to be approximately 54 x 16 x 20 inches, volume 40 gallons or 400 lbs. It will be supported underneath and strapped down, but sides and ends will be unresupported. can any one advise on thickness or lay up weight?
