Water tank
The best solution is a water purifier.
http://www.generalecologyeurope.com/naturepure.html
Sorry Jim but I disagree, the purifier is like spraying air freshener to remove a lingering smell, it does not cure the smell. I don't doubt the purifier removes some trace elements from the water, but I fear in this case, it will only mask a problem which should be fixed first.
Adding to that, a purifier in the system will mask future tank problems, a bacteria growth might go undetected for months.. years. My tanks are clean, they have not always been so and occasionally take on a taste, now I clean immediately. We drink fresh water from the tanks, which tastes as good as home, but it does take regular vigilance to maintain good clean water on board.
Just my 2p.
Out of interest, are you adding di-chlor, I have a large supply of this for my hot tub and have often wondered if it would be ok to shock the tanks occasionally using what is basically a swimming pool product.
I ask as the pool product is obviously not food safe, but then neither is bleach, is it safe to use?
