Water system question
nigelm
11 Aug 2008
me - hornchurch , boat - river crouch.
Some will remember that I had to replace a flexi tank after it split on me , well that's all done and I eventually got it all to work but now I have another issue
There is one pump operated from either the galley taps or the one in the heads when I turn on the galley tap water flows from the one in heads aswel :rolleyes:
But if only heads tap is turned on no water from galley tap , is the heads one worn out ? , it is same for hot tap also , any clues coz it's bugging me and using water twice as fast :eek:
Is this an automatic pump with a pressure switch?
Are these normal taps? If water can come out when they are closed then they can't be normal taps - they must be faucet types. In which case what triggers the water pump :confused: What have you got in terms of taps and pump?
I reckon that's an electrical problem. The switch on the galley taps triggers the switch on the heads tap. I can't quite envisage the wiring but it's somethng odd like an earth short on the heads tap.
