prv
Been doing some research and the Sigmar documentation suggests that the output from the calorifiers is BSP. Might this then be why?
Pretty much all plumbing threads are BSP
Oh. I was hoping that indicated that it wasn't the tapered jobby.
Oh. I was hoping that indicated that it wasn't the tapered jobby. Back to school for me.
If this was code I'd have invented a workaround in minutes.
I think with that sort of straight fitting you just need to use more PTFE.
If you're going to bodge it by sealing parallel fittings on the threads (and it is sometimes unavoidable) then a liquid thread sealant is better than just chucking lots of teflon tape into it.
curious,
anyone uses or knows cannabis (not the one you smoke, the one you thread around pipes to seal them...)
looks like this:
I do also wonder what is going to happen when the joints warm up - will expansion exacerbate the situation?
Dunno about thermal expansion of the fittings, but you will probably get an increase of pressure from expansion of the water. The first time my calorifier got properly hot after I replaced all the plumbing, one of the freshwater hoses blew off and pumped the whole tank out all over the engine bay. We were on our way over to St Vaast at the time, so after clamping the hose back in place had to make a quick detour via Haslar to re-fill with water.
