wakeup
Why ,, you driving?![]()
HA ha
I didn't think your shoulder would be up to skiing mate?
Wakeup
Touchee .. I thought you were offering to chauffeur, so that I can laze around in the manner to which I am accustomed - not me skiing!![]()
Interesting. It seems that they built indeed two slightly different engines in that power range.IIRC Mercury and Mariner made both a 2 cyl and 3 cyl 30hp rated outboard, and called the 2 cyl version the "light".
Quick google search also found this reference to it as the "portable".
I don't know any model year data, but it was available right up until 2 strokes were banned.
http://www.boatsplus.com.au/mariner...iner-30hp-portable-two-stroke-lw/prod_58.html
Sorry but a further twist to the saga.
The 'need' also includes monoskiing. Do I take it from earlier answers that this is a 'No' on my theoretical 3.4m 30hp rib? Thanks
Anyway, monoskiing EME? Didn't realise you were such a playboy? All becuase the lady loves Milk Tray?
You could just about start on a single ski behind my 2 stroke jet rib. It took a while and lots of zig zagging about half submerged, so far from perfect, but it was possible! That was using the single ski from a combination pair, and a pro type mono ski has a thinner tail and less lift, so even less perfect. My gut feel is that it may just be possible with a 30 hp 2 stroke outboard, perfectly propped, on a lightweight flat bottomed RIB with a single person on board leaning over the front, although i've never tried it, and I could well be wrong.
As Mapis said, you can't properly ski behind such a small RIB anyway, as you pull the boat all over the place, so its best just to consider it a bit of fun.
Not sure about what that means exactly, but imho by the time you'll be keen on running a slalom course (which is what monoski is all about), you won't be so interested in doing that behind a rib anyway.Not so much Playboy Club more Saga Club.
I would not recommend that to anyone. I for one would not even think of trying it, and not just now - also 20 years ago!There is a technique for lower powered boats where you circle the skier to get up speed and then pull out and away on the perpendicular to pull the skier out.
We are talking about a 30hp boat not a 380hp monster. Perhaps just taking a run up with the rope half way out would be enough so the rib can get some momentum to climb halfway onto the plane rather than take up the strain on the tow rope then hitting the throttle therefore having to go over the hump and pul the skier out of the hole.I would not recommend that to anyone. I for one would not even think of trying it, and not just now - also 20 years ago!
The key issue when starting with the pulling boat already going at some speed is to avoid as much as possible the initial water resistance.
And with a good synchronization, you can do that by jumping in the water as I previously described, because after jumping you will only "fall" in the water up to your kees or so, before being pulled out by the boat speed.
With deep water start, it's your whole body which has to overcome the water resistance, and by being snap-pulled, your back is at stake.
Even with a proper skiboat, the driver actually must use some care with the throttle, in deep water start.
I used to ski with some friends who had a 380hp skiboat, and with 3 of us aboard (when returning ashore, without anyone on the rope), the owner once gave full throttle upon start. I was sit astern, and the third guy was in the port seat of the observer, facing aft. But he wasn't expecting such dragster style start. In a second, he was projected at my feet, and just by sheer luck he didn't hit the rope pylon with his head...
No skier on earth would have been able to jump out of the water with that sort of pull.
I see what you mean, but it's a matter of how the acceleration develops.
Ideally, what you want is a constantly increasing pull, and not starting from zero speed, but rather with the boat running at her minimum RPM with the gear engaged.
That's what put less strain on your arms, legs and - most important - your back.
Any other types of start (jump start, beach start, and also the one you mention) are more critical, because starting from zero speed you get suddenly strapped, and the subsequent acceleration is actually poor, because the strong initial pull is only due to the boat inertia, not to its power.
As I said, jump and beach starts are indeed feasible (been there, done that).
But starting from deep water with the the boat launching with the rope slack... Not for me, thanks.
I would even refuse to pull someone, if asked. Too dangerous.
Can't argue with that.
Actually, I did say "if and when you would really fall in love with the double binding". By which time, he must have built up quite some experience...![]()
When I was younger I had a 3.1 Avon with a 15 which pulled me out easily. I later upgraded to a Zodiac 340 with a 30 and that was plenty of power. I wakeboarded - so not much wake to jump with, but great for a youngster to learn.![]()
