trondhindenes
New Member
Hi all,
I hope I can get some pointers & opinions on the following problems:
I've been chasing an intermittent engine hesitation issue all summer, not being able to get rid of it. I know it's due to fuel starvation and while at first I was afraid of contaminants in the diesel, I'm 95% sure it's an air leak in my fuel system.
The first thing I tried was to replace the existing CAV water separator with another unit, but I quickly discovered that the internal seals in the unit were leaking from the factory, so I scrapped that and installed a higher quality racor unit instead. The problem, unfortunately persists.
A few things I'm seing:
If I bypass the water separator, hooking the hose from the tank directly into the engine's fuel pump everything works flawlessly. I don't consider this a valid fix tho, I want a water separator in my fuel system.
With the water separator in place, the faults are quite intermittend. Yesterday the engine ran for 7 hours without problems, while this morning it stopped within 20 minutes of running.
I'm also noticing that the water separator is installed so it sits slightly higher than the bleed screw on the engine - I don't know if this could cause trapped air in some situations.
I'm also starting to wonder if the fuel pump on the engine is starting to go bad, and simply is unable to handle the extra vacuum needed to pull diesel thru both the water separator and the primary filter.
So TLDR:
- engine runs perfectly fine without a water separator in place
- engine stops randomly with the separator installed.
I'd be very eager to hear your thoughts, I'm going in circles on this one
So TLDR:
