samwise
I cannot get any flow from the taps in our pressurised fresh water system. The pump runs, there are no leaks that I can see and the accumulator also looks ok.
The problem arose after the tank ran dry when a tap was left running ( at a comparatively low rate) for about three hours. It is a Flojet diaphragm pump, so I don't think it has burned out.
I refilled the main tank and opened all the taps in the system before running the pump. It makes all the right noises, but the taps remain dry.
I suspect an airlock. What's the best way to clear it and how can I establish that the pump is not damaged?
