asteven221
Our Sealine has two deck fillers that are installed flat on the side decks. I think this is a common arrangement although I always feel is very vulnerable to water ingress to the tanks. We've never had any problems and I do pay attention to making sure the O Rings are new, but at the end of the day I just don't know if they work. There could be a significant amount of water in the tanks ready to give me some grief for all I know. There aren't any drain taps either.
You would think Sealine would have given some thought to installing a drain valve.
So what do others do with the same setup? The only thing I can think of is to try to get a pipe down to the bottom of the tank and draw up some fluid. Initial efforts with a thin plastic pipe i.e. the kind of pipe used to hide wires, didn't work due to what I likely to be a bend in the fuel pipe. Does anyone have any other ideas I could try.
Thanks.
Thanks.
