vasant
Hi all,
On my maxi 84 there is a transom hung rudder which IN THEORY is less affected by water penetration. Nevertheless when lifting out the boat I noticed a considerable amount of (stinking) water comming out of a little hole near the lower part of the rudder.
I understand this is not unusual nevertheless it should be fixed. As i am a recent owner I do not know the story of this issue but i saw some points at the edge where the water could easily penetrate. To cover everything up with some epoxy resin should t be rocket science but i would like to be sure that the structure inside is in good shape. Does anyone know what the inside of these maxi rudder is made of? On the higher part at least it feels very robust....
I am thinking of opening some holes to dry out, fill with polyurethane foam and then re-laminate the whole wetted area. In some other forum I have read of something like a "draining plug" on a rudder... Could it be that its on purpose to fill it up?? dont think so.....
Thanks for your ideas.....
