Water in power steering reservoir Volvo penta D6 370 DPH
GaryAH
28 Jul 2020
Hello. The power steering oil in the in the power steering reservoir for a Volvo Penta D6 370 DPH has emulsified due to water ingress, a visual inspection of the steering rams didn’t reveal anything obvious. Does anyone have any ideas as to the most likely cause of the problem. Cheers Gary.
GaryAH
28 Jul 2020
Thanks Julian, I was just thinking if you get water in via the rams you might have expected to see some oil coming out or some pitting / corrosion but they look really clean. I’ve got an engineer coming to look on Monday so I guess he’ll confirm it’s the rams. Glad to hear they’re not as expensive as they used to be. Do you know how roughly how much they are these days. Cheers Gary.
Portofino
10 Apr 2011
Boat- Western Med
Any ram left extended under water will attract abrasive growth on the shiny smooth extended bit .
This abrasive then destroys the rubber ram seals and water ingress leads to emulsification.
You notice a rainbow film on the surface water at the stern if it’s pressured up as the oil leaks out .
Thats why it’s best to park a boat with the trim tabs up , nothing exposed .
How ever if the steering rams are under water usually a L + R then it’s impossible to protect both simultaneously.As when one side is closed the other is fully extended and exposed.Parked straight ahead both are 1/2 extended.
Would you want pressure on an outdrive set of the bellows for long periods anyhow If you did park them hard over ?
DPH leg is notorious for steering ram fails as a result.
Previous DPG on the KAD 300 has one ram located inside the transom , dry and out of the water and as result an uneventful ownership experience.
Orthop
23 Jun 2019
Probably you have to change the steering ram regularly. I changed the ram after 4 years (bought the boat from new). Last season I had to fill up the oil at the steering wheel regularly, so we changed the ram during the winter period again.
alt
24 Oct 2006
Éire
And the out-drive fully trimmed down (also means no stress on the bellows).
As P mentioned, with the DP-G (And 290's etc) the steering ram is inside the boat, so not a concern.
Any time I see people with their out-drive trimmed out in our yard, my blood boils. I always advise them to leave the drive fully down and in center position so 1) no trim rams exposed and 2) no stress on the bellows.
GaryAH
28 Jul 2020
Portofino thank you for your reply. I guess when I replace the rams I try and seal the gaiters that cover the piston rods as best as I can to try and prevent marine growth which may make the rams last a little bit longer.
alt
24 Oct 2006
Éire
I think you can now buy gaitors / bellows for the steering rams?
GaryAH
28 Jul 2020
Yep, agreed. The boat is 9 years old now and I only bought her late last season and couldn’t see them being replaced in the service history. I’m new to all this having previously had shaft driven boats.
GaryAH
28 Jul 2020
Good to know having only had shaft driven boats before. She’s out of the water now for all those Winter jobs with the leg fully down and in the centre position (y)
mcanderson
24 Sep 2006
London/SofF
219 inc VAT from Key Part - Keypart
I have just bought two for my boat.
spannerman
30 Nov 2002
Check the hydraulic hoses also, these have had 3 upgrades due to persistent failure, in fact Volvo have had endless problems with rams and hoses and trim cylinder hoses, lost count of how many I have replaced on recalls and under warranty. Also make sure the engineer flushes the entire system as the contaminated oil if left in the system can damage the shuttle valve mounted on the transom at the back of the engine and hard to get to, the piston rusts and then your helm steering doesn’t operate the valve which controls the pressurised oil from the servo pump.
julians
11 Jun 2006
The rubber gaitors do increase the length of time between needing to replace the rams, but they dont eliminate the problem completely.
julians
11 Jun 2006
on most rams you can remove the end caps, remove the cylinders and replace the seals
There do seem to be rebuild kits available for the dph steering rams, but nobody seems to bother using them. Maybe because if you're paying someone to do the work the additional labour involved in rebuilding the ram is more than the cost of just buying a new ram? I dont know....
simonfraser
13 Mar 2004
i did mine, only alternative was new rams for which the engine likely had to come out
main bit of fun was getting the caps off, pm me if you want further info
julians
11 Jun 2006
That presumably wasnt on a dph drive? on a dph the rams are easily accessible because they're entirely outside the boat under the water
