finn00
I have salt water in my oil, it is fresh water cooled, the mechanic says it is coming back from the exhaust. any thoughts?
Is the level of the engine oil increasing?
Do you have an engine oil cooler that is leaking as engine oil coolers are cooled by sea water.
never ceases to amaze me when peeps say that water comes back from the exhaust and enters sump! If it comes back up exhaaust then it gets past the ex valve and enters the cylinder. To get in to the sump it has to get past the piston rings. If it was that easy for water to go past the rings then there would be no compression. My guess, either oil inter cooler, rusted through engine parts (unlikely) or most likely if the raw water pump is integral, a worn back water seal.Cant be the head gasket on a fresh water cooled engine, surely? Salt water shouldnt be anywhere near the gasket. Is the seawater pump driven directly by a take off from the engine or is it belt driven? If its direct drive , then the oil seal could have failed allowing seawater into the sump. Otherwise it must be coming up from the exhaust as suggested by the mechanic, and you have been lucky not to destroy the piston by hydraulic locking.
It's unusual for a cooler leak to let seawater into the coolant as the coolant pressure is almost always considerably higher than the seawater pressure. However, in some Volvos in particular, if the exhaust manifold is caked up the seawater pressure can increase enough to breach the cooler seals. However, this would not allow water into the engine, only into the coolant, which will usually overflow into the bilge.
Seawater can get into the engine as suggested if the pump is driven by the camshaft and its seals fail. Also from the exhaust manifold into the engine via the exhaust valves but this normally happens only when the engine is stopped. Can happen if the trap is not big enough or if the engine is turned over for a long time on the starter motor.
S
I know this can happen because I have seen it in an engine in perfect condition. Like you I thought it was impossible but I suspect it may go up the side of the ex valve guide. The engine had hydro locked but fortunately sustained no damage. After the oil had been changed several times there where no further problems."
S
How does valve overlap allow water from exhaust to oil??
I did wonder if the problem arose from an oil test, hence post 8.
Chloride might show in v. small amount in most marine engines IMO.
Could be nothing to worry about.
I have saltwater in my oil, showed up on an oil test. I was told it was caused by valve overlap. which saltwater can get in from the exhaust. Mercruiser's fix was to install resonators. has anyone had this problem and is that the fix?
Read more at http://www.ybw.com/forums/showthread.php?443875-water-in-oil#dejgXerSiVGTavTO.99
I would question whether your statement here that seawater pressure is less than freshwater pressure is correct. When my heat exchanger (VP TAMD60C) developed a minute pin hole puncture the fresh water system filled from the seawater, not the other way around, manifest by coolant gathering in the bilge through the pressure cap. Even at 95oC the increased pressure in the freshwater system will be less than 1 bar, but the positive displacement seawater pump will easily achieve 2 bar.It's unusual for a cooler leak to let seawater into the coolant as the coolant pressure is almost always considerably higher than the seawater pressure. However, in some Volvos in particular, if the exhaust manifold is caked up the seawater pressure can increase enough to breach the cooler seals. However, this would not allow water into the engine, only into the coolant, which will usually overflow into the bilge.
