driver0606
I cannot believe I could be so stupid. Whilst heavily distracted, I checked for the water level in the front filler cap of the engine and found I could not feel it with my finger. After adding 2 litres of water/antifreeze mixture, I smelled a rat. I was using the oil filler!
Without starting the engine, I immediately drained the oil (water was the first thing to come out), put back some of the water free oil from the top of the oil removed, to try and flush any more water down, and drained that. I then refilled the engine with used but uncontaminated oil from the other engine. Hoping to flush any other water down into the sump. However, the water would have flowed more easily around the engine
My next plan (in 7 days time) is to drain the some oil out of the bottom of the sump, then run the engine until warm, then change the oil and filter for new. I am concerned as to whether some water may have remained in any pockets on the way down to the sump, or at the bottom of the sump. The sump drain is a well placed fitting, but must be slightly raised inside, trapping some water. Should the new oil look cloudy/emulsified after running, I would change it again.
Any comments on my plan, please? I am hoping Latestarter will see this and not consider me beyond redemption. Oh, by the way, the remote key for my car failed in the evening of that same day, locking me out!
