sarabande
I missed SIBS, so apologies for this. ( I have done my homework on previous 2006 threads ! )
We have a close sailing friend who has developed a pretty heavily-compromised immune system, and we want to ensure that our on-board drinking water is as clean from impurities and bugs, as possible, so that she (and we) do not have to worry about bringing bottled water on board, which is our present, clumsy and expensive, practice.
Apart from filling the water tank, bunging in some evil (cheap !) agricultural sterilising chemicals, and then emptying it, what advice can Forum members give in response to the following issues, please ?
<u>Supply side into tank</u>
We are buying our own water hose, but what sort of filter can be used at the delivery end to ensure that particulate, or oocyst contamination is removed ? Are there any filters which we can use at the same time to remove bacteria ? These filters must work at a relatively low water pressure from the/any marina's pontoon tap; if this is not practical we have to filter on board, so....
<u>Delivery side from tank</u>
This is probably at a higher pressure than shore supply, so what
filters would you advise to ensure that we can produce cold and hot "cleaned" water ?
<u>System</u>
There's a 150 gallon fresh water tank, to a pressure pump which delivers both to the coldwater system and to the immersion heating tank, thence to a galley sink, a handbasin in the heads, and a shower.
This may sound to be rather OTT, but we are prepared to do as much as we can to avoid the risks of any water-derived illness for our frequent, and loved crew member.
I would be grateful for any practical advice on design and set up of a system, and for recommendations of suppliers / manufacturers of readily available filters or cartridges. I propose to do the work myself (i.e. help the family's Chief Technical Operations Manager to do it !) so bonded suppliers who only supply and fit are out.
In anticipation, many thanks. S
<u>System</u>
