vyv_cox
Having an aircooled fridge in a hot climate , I find that the cockpit air temp is so warm around the fridge that it runs almost continuosly . This is a new fridge too . I am thinking it needs a cooler air supply , so as its a cat I wondered about making a , say , 50mm hole in the bridgedeck , which is well out of the water , to feed cool air directly under the fridge .
A water deflector would need to be fitted to stop any splashing water and then , perhaps a solar vent in the coachroof to expel the hot air ?
Is this a bit desperate, or may it work ? ?
Many people find a small fan blowing on the coils to be quite effective. I think the extraction of the hot air is more important than a cool air supply. The air to mine came from low in a locker where it was cooled by the sea. The problem was getting the hot air away, as it followed a tortuous route back into the same locker. Even in Holland the fridge was working hard.
