Mr Googler
I did note that the pressure only rises by about 20 mh20 (or 0.2 bar) when the pump is running. Is that normal? It certainly feels as though something is stopping the compressor from even trying to start.
Oh dear you asked the R22 question ! I will try to keep this short.Thanks again superheat. So am I right the cut out will trigger on both low and high pressure? Given the compressor doesn't even get going, out of gas?
I'll get my air con chap down.
What's the best replacement for R22 gas? Any idea on quantities in this size system. Asking a lot I know!
Much as I fancy a trip to see you three legged folk, I may have to pass presently.Had it confirmed today that I have no gas pressure.
I am finding out from condaria what the gas weight is for the system. The next hurdle is finding a supplier for replacement gas. My air con chap on the island doesn't have either r417 or r422 and is making some calls. I fear it could be tricky as most supply in 9.5kg bottles. Add shipping on that to Isle of Man and things are getting a little silly price wise for a regas!
Fancy a trip to the Isle of Man Trevor with a bottle under your arm![]()
Oil stains are the number one indication of a leak so you have likely found the problem. I trust you will get the problem resolved, but please contact me if you need further advice. I don't have any client contacts on IOM, but have some contacts in Liverpool and Belfast who might be able to help.Thanks Trevor. I think the leak is at the controller. One of the connections is gooey for want of a more technical term. A new danfoss controller is quite cheap but will nip the connection and see how we go. Thank you very much for all your help. I'm not native so just the 2 legs for me!!
