georgieboy
I have a grey holding tank conected to a masarator pump .The pump has a run dry cut out switch .I cannot get it to empty the tank it runs for a few seconds then cuts out.I have rodded the waste pipe to ensure no blockage from the tank to the pump ,all clear.the outlet from the pump out through to the skin fitting is also clear.
I did get a big bubling noise from the tank with the pump running a bit longer .
I have changed the pump and the old one took apart and tested all ok.
I can only think that air from a fitting is stopping a vacuume forming but I have tightened all of the fittings and cannot see any seepage to point to a leak.
Any ideas please
Any ideas please
