[3889]
I've lost the oil drain bolt washer on my Tohatsu 3.5hp outboard. I could do with getting an off the shelf replacement asap rather than wait for the proper Tohatsu replacement. The drain is weeping, as you would expect.
The Tohatsu part is listed at 10.2 mm ISD, 19 mm OSD and 1 mm thickness.
Standard M10 (form A) washer is 10.5 isd, 20 mm osd and 1.5mm thick.
Will this seal the oil drain and is A4 stainless a suitable material for this purpose?
