tillergirl
Out on the East Coast on Wednesday, the CG MSI announcement reminded me about something I meant to ask a while ago. The CG announce weather forecast broadcasts and the channels they will use according to which aerial is nearest to you - no trouble with that since it can be quite long and otherwise would hog too much of Ch 16 - but they say that broadcasts about high speed ferries (out of Harwich) will be broadcast on another channel (72 I think is is) and you should listen to that. We are also required to listen on the VTS port channel if in that area.
Now the VTS channel clearly must be separate but why a third channel to listen to. There is no warning when the warnings will be broadcast so you would have to listen all the time. What's the point of all this; if there needs to be a warning either do it on 16, where people are listening or say, we are going to do it on 72 in a minute if its too long. Is this too simple?
