Little Dorrit
I have one of these (original I expect from 1986) and it seems to be working well. However there is a sound whIch appears to be coming from the exhaust/combustion chamber below the heat exchanger. The best way I can describe it is a kind of 'gurgling' sound, quite clearly the sound of air or exhaust similar to the sound you get by blowing across tube or pipe. I suspect the flow of air or exhaust is being restricted. Has anyone else experienced this and if so is there a modification or fix?
