freddyuk
Lots of posts on the web about failed fridges but replacements are very expensive so want to check if I have failed controller or compressor. There are no standard mini fridges that will fit the space I have so its fix it or go without.
It is standard BD35 with 101N0220 controller. No fan. The fridge has never worked since we owned the boat. Putting good power into the system does nothing. I have done the LED test and I get 5 flashes. That is thermal overload. I have checked the compressor pins and there is 3 ohms across each so that seems windings are OK.
So either I need a new controller or the gas has escaped. Would you guys concur? If gas has escaped I presume the compressor would start up at least?
Thanks.
Thanks.
