[185615]
I have taken 2 photographs. 2.jpeg is I presume the exhaust elbow. 1.jpeg is showng the exhaust pipe from the elbow going down to a white box from which the pipe leads to the transome. Is it possible if the elbow is clear the box could be partialy blocked, bu, if so would there be steam so far from the heat source?If he said 'water passing up through the injector sleeves' that would mean water is being ejected out the top of the sleeves, you should be able to see that around the injectors when the engine is running. So check for this, he could be correct about the sleeves if this is the case. Water can dribble from the bottom of the sleeves when cylinder is on the induction stroke and cause smoke/steam. But there are other causes that need rulled out first before removing the head. As has been said check that exhaust elbow first.
