Sailorsam101
When i did my raw water pump last weekend it all went fine....then this weekend i started to think about how it went.
When i pulled the water input pipe off the bottom of the pump all was fine until it fell down..then water poured out...obvious as it was now below water level.
So i thought last night...what happened it if split under the engine....NO SEA COCK...WTF.
So if the pipe splits under the engine of comes off the through hull fitting the boat will sink and there is nothing i can do about it.
OK so it may never happen but i for one like to be able to seal off all my through hull fittings...!!!
I am amazed that this design was used.
