Leighb
The saga continues. We have sorted the calorifier problem and have piping hot water, however yesterday was our first opportunity to take her out to sea and open her up to see how the engines behaved.
All OK up to about 2500 RPM. Port engine - with calorifier - steady on 70C , Starb around 80C. On opening up further she accelerates eagerly to 3200 RPM which is fine, but the temp on the Starb engine also accelerated upwards.
Within a couple of minutes it reached 95C at which point I throttled back to 2500 and quite quickly the temp sank back to 80-85. The Port engine only rose to 80C.
Thinking about it I suppose the temp might have stabilised at the higher temp, but it seemed to rise so quickly that I was nervous and didn't want to push it further. Should I perhaps try again and see if the temp continues to rise, and if so, how high can I let it get?
The raw water impellers were replaced at the service last autumn, the intake strainers are clear, so no obvious cause there. Is it most likely to be the tube stack that needs cleaning out, or is there any other area that should be investigated? I assume, perhaps incorrectly that the thermostats would fail open so that the engine would tend to be too cool rather than overheat?
This engine incidentally has been fitted with the later TMD40B design heat exchanger which should be easier to clean?
Any comments/advice would gratefully received.
