Carduelis
I did a routine service of my engine yesterday. While replacing the primary fuel filter I stupidly twisted the seal resulting in an an air leak. The problem was easily identified and fixed, but I was left with a fuel line entirely empty of diesel.
My problem was that no amount of wiggling of the manual lever on the lift pump seemed sufficient to refill the line and filter bowl, let alone the secondary filter. The line requires suction along its entire length; there is no 'gravity' section. I eventually got it started after manually filling the filters.
Should I infer from this that the pump is on its way out, or is this normal? The engine otherwise runs fine.
