A_8
I took the boat out for a run last weekend and opened the throttles fully. To my surprise the boat was underperforming and the port engine was running at 100-150 rpm's lower then the other engine.
I figured it could be a fuel flow issue or the Turbo. The engines are now at 800h+ and I seem to remember there is a sort of consensus that these turbos may start to fail at around 1000h.
I know you can check the center axle in the Turbo, which I've done before but will that be sufficient, can the problem with the Turbo be more subtle and need other methods of checking?
Anyone know?
Thanks/
Michael
Anyone know?
Thanks/
Michael
