VP DI30 hour meter
billyfish
6 Oct 2020
Any one know if the hours recorded are linked to the revs or is an hour a hour when the ignition is on. In other words can you work out the lts per hour
An hour is an hour whenever the engine is running and consuming fuel. You should get just shy of 2l/h in normal use with a D1 30.
Thanks that's what I thought. But I was hoping for more like 3 lt my old lister petter returned 3.5 ish. But I didn't have a meter
Why would you hope to use more fuel? all modern 30hp are equally efficient and if properly matched to the boat will give between 1.75 and 2l/h
