VP D4-210 hp upgrade to 225/260 hp
AllanG
5 Apr 2005
Hamble, UK
Does anyone know if a VP D4-210i-A can be upgraded to 225 or 260 hp spec and, if so, what is required and what would be the approximate cost?
Many thanks,
Allan
Lots of bits are different: cylinder heads, turbo, ecu, etc.
260 has a supercharger as well.
The cost would be prohibitive - it's a non-starter, imho.
Sorry :(
Many thanks,
Allan
I presume you normally run @ 60-80% max revs ???
when you have spent £1250 on a chip box / new prop etc I presume you will still run on 60-80% max revs.
Why not save all the upgrade cost and just run on 100% max revs. now.
I'm confident your engine will not last as long which ever option you choose but you will have at least saved the modification cost.
