BartW
Some will remember that in January this year I had the starboard long block Volvo Penta D3 exchanged under warranty (only 300hrs). To summarize a long story, after a few intermittent “fuel supply” errors, and VP service center visits, they did something wrong while replacing the fuel injectors, and badly damaged the first cylinder, so that the complete long block had to be replaced.
Although the succession of visits to VP service center with my boat gave me some headaches and frustration,
At the end I was very happy with the service as everything was done under warranty, while the original fault (air sucking in the fuel line) was no real Volvo fault.
This engine has done 220 since then without a glitch.
In june this year we had a serious problem with the port engine; during a diving trip, heavy loaded with 8 divers and their stuff, and at high power 3500RPM (engine max is 4000rpm), at a certain moment I noticed that the temp gauge was at max, the engine was fully overheated, I didn’t notice the warning light, it was hidden behind the throttle.
We stopped immediately and discovered that one’s again a hose from the Raw water cooling cirquit had come loose due to the strong pressure caused by a full weed filter (this has happened before a year ago in Croatia on the other engine).
Luckyly this time there was not yet much sea water pumped in the bilge.
After re-fixing the hose, and cleaning the filter, the engine started without a problem, and temp became back normal.
This trip was finished 10 minutes later.
One hour later (engine was almost cold) we started again to another destination, and then after 15 minutes cruising I heard a strange noise coming from that engine. When opening the hatch I noticed that a small string from the serpentine belt came loose and was smashed against the hull at every cycle from the engine. I was able to cut away that string, and continue the trip with a smaller but still working serpentine belt. Hot water has been streaming over this belt !!!???.
We continued the trip and 15 minutes later after a strong WOEF sounding from the engine it stopped promptly. Restarting didn’t help, the engine was completely dead. We limped to the marina and the same evening we dropped the boat at VP service.
They next day they discovered very fast that the screw from the timing belt tensioning pulley was broken, and due to that the timing belt came loose (This timing belt is under a plastic cover on a D3)
Cylinder head and valves were badly damaged, so a complete replacement of the longblock was the best thing they could offer, but as the boat was JUST (one month) out of warranty, they suggested this was going to be a insurance case. I informed the insurance company, but had fear that their reaction was going to delay things, and as all this happened exactly 2 weeks before our 4 weeks summer holiday in Croatia, (planned with family and friends) I didn’t discuss about the warranty versus insurance issue, and confirmed that I would pay the bill while waiting for the insurance to react. The VP service center did a very good job making sure that the boat was repaired before our holiday, the office guy to find and get a new longblock supplied as quick as possible, (first indication of delivery time was 2 months ) and when the block was delivered 3 day’s later, straight from Stockholm, the service engineer did some night and weekend work to replace all items from the old to the new block and put the engine back in the boat.
Just a couple of day’s left for testing the boat in local water before leaving with her to south Croatia (and cruising to Italy !
). Great respect and big thank you to these guys!!!.
In the mean time, after several phone calls to remind them, the inspectors from insurance only contacted us a month later (we were on holiday, the broken engine block was at VP service center) inspection was done at VP service, 2 more weeks later. (I was not there)
Only now in October after a few phone calls we have been handed the results from the inspection, and conclusion from the insurance company
They will reduce the amount that they will pay me with 3000 euro (I payed 13000 euro) because VP has put in new fuel injectors, while the old ones could have been re-used.
VP comments on this, it is extremely difficult to get the old fuel injectors out of the old block without damage,(re experience with the other engine) so it would be less time consuming and less costly and more reliable to put in new injectors.
The insurance will also deduct 600 euro ,minimum fee, as stated in the contract.
Secondly they will try to recover the rest of the amount from Volvo as this broken nut may not happen after 350 hrs, so should be warranty.
9400 euro should be on my account by now
Now these are my questions:
1) Should I try to get that remaining 3000euro from the insurance company, it was a VP decision not mine, that they have put in new injectors, to be the most cost effective repair.
2) Should I try to get something from Volvo while this seems more a warranty issue
3) The insurance inspector was not convinced that the broken screw had something to do with the overheating, no part of the engine looked overheated pure coincidence they say. Now I don’t believe this, there was a definite succession of events before final shut down.
4) I am mad at these inspectors, they told me that they want to be involved BEFORE repair is done , they were informed the same day that VP discovered the broken cylinder head, but they reacted with much delay, Should I react on this ?
Or should I just forget about it. After all we had beautiful holiday (s) sinds then, and 170 hours on the counter of that new engine since june ! And There are now two almost new engines in my boat while all this has cost me only 3600 euro. (live is too short and more important things to do…. )
What do the technical and legal specialists think ?
I didn’t want to go much in detail to make the story as short as possible, would be glad to give more detail. I’m sorry for the bad English wording.
