KajLehtinen
Hi!
Got a Sealine T52 with twin D12-675. According to VP manual it should have approx 44 liters (actually says approx) when mounted flat, and 33 liters when mounted with a 8 degree angle. Was down and measured my engine install with the cellphone and according to two different apps the mount angle is 6 degrees.
Any idea on what that means in oil level when we do oil change in a couple of weeks? Should I draw a graph with 44 liters at 9 degrees and 33 liters at 8 degrees and look at 6 degrees to see where the line crosses the liters ? Also does the engine manufacturers recommendation end up in the middle of the stick or at the top of the stick? I assume the oilsticks markings are only correct when the engine is mounted leveled ?
Sealine didnt bother to write anything in its standard manual for the Sealine T52, not that I've found atleast.
/Kaj
/Kaj
