West Coast
Hi all, away cruising, but engine playing up. Engine is VP 2003, fresh water cooled,
Engine overheated 3 days ago, problem traced to failed FW pump. The pump bearings had failed. I sourced a spares kit which included new shaft, bearing, water seal and impeller. On dismantling the pump, I noticed the impeller had badly scored the inner face of the casing. However, the marine engineer thought it should still work ok with the new parts.
Salt water cooling circuit was checked, all seemed ok. I also dismantled and checked the heat exchanger, all ok.
Repaired pump refitted, engine run under load on the pontoon, all seemed ok. Small amount of water was noticed to be dripping from the header tank cap relief valve, but this wasputndown to overfilled tank. As engine temp built, the FW cooling pipes heated up, signalling the thermostat was ok. So all assumed ok.
However, later on the engine overheated again, after say 30 mins at moderate revs 2000 rpm. FW system had emptied again under the engine. No sign of leak except again water had been coming out of the heade tank.
Any pointers? Could there be a blockage caused by debris from the scored pump? Or if the pump is not working properly ? Wild either of these cause the FW to empty itself in this way?
