vic008
My sparky says too slow. No room for bigger crank size, and cant go smaller on alt due to oil filter in the way. Anyone have a way around this? Mount alt differently?
What voltage is it producing? How many amps are the batteries absorbing?Yup original set up.
Am told alternator needs to spin at about 2500 to really do anything.
That is because your battery is close to full and that is all it will accept. Nothing to do with the alternator speed, although obviously the higher the engine revs the greater the output. What you are experiencing is quite normal. If you have a charge system that charges the engine start system first you will get high output just after the engine starts then it will fall away to the level that the batteries will accept.
We don't know who your "sparky" is but I'd suggest that you find a new one asap as I've rarely heard such tosh.My sparky says too slow.
Is it getting to 14.4V straight away?14.4 v Sometime run engine for an hour and do 40a going down to 6a Sometimes go whole hour at 6 or so amp
I had a 2003. 240amp battery bank. Fitted an Adverc charge controller to charge faster, and replaced diodes block with a VSR.
An Adverc (or other add-on regulator) will compensate for any voltage drop at the diode splitter, so there's no real need to change it for a VSR.
