Aquafennatic
New Member
I´m having issues with my Starboard engine which I need help with. It overheats under load at about 2000RPMs and will quickly cool down when I reduce RPMs. It appears to be getting worse over the last couple of seasons. I´ve replaced the Seawater pump, cleaned the Seawater side of the Heat Exchangers and After Coolers. Cleaned the Reverse Gear Oil Cooler. Checked the Sea water path including the Thru Hull valve, Sea Strainer, Exhaust Elbow and all engine pipes for blockage. The antifreeze is new on the freshwater side and I´ve replaced the Thermostat, however I haven´t looked at the circulation pump or cleaned the freshwater side of the Heat Exchangers. Below you´ll see a chart of the temperature in degrees Fahrenheit. This test was conducted at the dock. I´ve noticed that the difference in the temperature of the antifreeze before & after the heat exchangers on the starboard side is only 20 degrees at high revs thus I´m suspecting it´s a sea water flow issue at high revs. The temperature of the Starboard engine that are indicated below is higher when the vessel is under load. (The gauge reads 200 degrees at 2000RPMs under load). Can anyone recommend next steps based on what you see below ...
1500 RPM 2200 RPM
Measurement points Port Star Port Star
Before Seawater Pump 73 73 73 73
Before Heat Exch 1 76 79 74 80
Heat Exch 1 Cap 79 79
After Heat Exch 1 81 82 83 113
Heat Exchanger 2 Cap 79 107
After Heat Exchanger 2 85 88 85 132
After Cooler 1 Cap 79 118
After After Cooler 1
After Cooler 2 Cap 79 117
After After Cooler 2 78 86 128
After Oil Cooler 80 88 127
Exhaust Elbow 83 85 86
Into Heat Exchanger 158 173 152 176
Into Circulation pump 101 113 105 156
Thermostat Housing 167 178 165 179
Please let me know if you'd like me to send you a more readable version of this table.
1500 RPM 2200 RPM
