rpoperdigao
Hi!
I have a saildrive 120S and it seems that or the line cutter or the propeller hub got worn out (or both) and now when I place the nut at the end of the shaft, it gets to the end of the threads without properly holding the propeller hub in place and there is some play. The shaft itself does not have any play. I bought a new line cutter hopping that it would fix the issue but unfortunately it still has some play.
When I check the manual drawings, it looks like the conic line cutter should have the bigger side close to the saildrive and the shorter side closer to the propeller hub.
However, I also noticed that if I rotate the line cutter, this play gets solved since the propeller hub gets pushed to the thin coned metal instead of pushing the solid thrust washer.
Do you have any tips on how I should fix this? Should I keep the line cutter the other way around? It won't prevent a line of getting into the saildrive sealing but stops the wobbly propeller... If you have any tips on how to solve this I would really appreciate!
