pistonbroker
Hello all. A long shot but here goes. This system has been well discussed and appears to have some fragility issues. I had to replace an interceptor two years back, these things happen. I'm not really in the market to replace the system just yet, but may well do so in the future. I have fault code EC 2 (SB side 3 & 4 flashing LEDs on the control panel) which suggests a comms fault.
The SB interceptor is stuck down, and the PT interceptor will not move at all and is currently stuck in. Have tried giving the SB one some "encouragement" but to no avail. If I swap the SB and PT connectors around on the control unit nothing changes other that EC 2 goes to EC 3 (same as EC 2 but PT side 3 & 4 flashing LEDs on the control panel). I have checked the cables as per the manual, but short of doing any continuity checks at this stage.
So to the question: Has anyone had a control unit fault (the box that accepts all the plugs from the interceptors and the control panel itself? Does the description above sound similar to what you may have experienced and that replacing the control unit resolved the problem? Just want to try and narrow down as best as I can to ensure I change the correct part. The interceptor of course is boat out adding more expense...
Is there anyway to test the control unit - it appears to be a moulded unit with no access to do any basic fault finding. I can of course do point to point continuity checks on some of the harnesses which I will do next weekend.
From the manual.
- EC 2; Flashing: LED number 3 and 4 on port side are flashing. Error: Indicates that no communication is detected between the control unit and the interceptor(s) on port side. Action: Check so that the cable(s) between control unit and the interceptor(s) are connected properly. Check so that the cable(s) are not damaged.
Thanks for any help in advance!
From the manual.
