mattnj
Hi,
Volvo 290 leg with stainless props and the behind prop anode, problem is that it had almost completely dissapeared and was new a the beginning of April this year. Is that a normal rate for one to corrode? Do i just need to get use to changing it 3 times a year or am i likley to have a problem elsewhere?
I have a galvanic isolator fitted already.
Can i fit more anodes? if so how, where and what type?
Are the Active corrosion prevention systems any good that Vovlo sell?
Can i buy a big fat anode and stick it in the water on a bonded wire when i am not on the boat? Or will that make it worse?
Thanks in advance.
Matthew
Thanks in advance.
Matthew
