Rocksteadee
Volvo Penta overheating
I have a Fairline Turbo 36 fitted with Volvo TAMD61a engines and have one over heating over 1800 RPM
Tests and jobs done so far.....
All 3 heat exchangers removed and de scaled
New impeller and wear plate and cover
Thermostat tested against a known good one (open before good one and fully open before and wider than good one) it was marked at 75 deg
Calorifier circuit isolated
New antifreeze
At 2100 rpm temp creeps up and temp alarm sounds at about 95 deg on gauge so have assumed gauge read ok.. Other engine alarm sound at about same temp before I had the heat exchanges done so have assumed sensor setting about the same
Other engine now runs a constant 82
Is it possible that the engine can generate more heat then the exchanger can cope with
Are there any 'known' problems to cause this as I cannot even run at high enough revs to keep the turbos spinning
Perhaps I could call her a Fairline 36
Any response greatly appreciated
New antifreeze
