Volvo Penta Tachometer adjustment
superheat6k
10 Jan 2012
South Coast
One of my Tachometers is reading 150 revs high (I have to set it 150 revs higher than the other engine) at crusing speed. I have checked this against the other tacho, and with a laser tacho on the engine itself.
Does anyone know if Volvo Penta Tachos can be adjusted to show the proper reading ?
Yes they can, or at least the ones on my last boat could. I think there was an adjustment screw on the back.
If it's the one with the digital LCD, then yes, they can be adjusted. There is 2 adjustment buttons/screws at the back.
I apologise that I don't have the instruction PDF anymore, but a Google may bring it up?
Depends what type they are. The ones on my lower helm have the old scrolling numbers hour meters, and they have a plastic plug in the back, which you can remove to access a small adjusting screw. I had to adjust one of mine this way after it had been repaired. The ones on the flybridge though, seem to have no adjustment that I can see, which is a pain as they are both incorrect!
