moresparks
Hi.. Should I worry...
Volvo Penta sterndrives -290 SP-A’s about 30 years old.
I have them both at home for general cleaning and painting.
When I drained the oil from both, it was as good as it went in – no hint of water contamination.
Pressure and Vacuum tested – one is spot on according to the Workshop Manual. The other – not quite!
It will hold correct pressure for hours – but the vacuum is slightly down. Looking back on my notes it doesn’t appear to have changed since the last time I checked.
I can evacuate to around 12 / 13 ins HGa then it very slowly leaks to around 9ins HGa and then holds for hours. I believe it’s in specification; but different to the other drive.
I have replaced the Gear Shift (Eccentric Piston) seal and O ring but only a slight improvement.
I could replace the shaft seal but wondered if I was wasting my time, on top of that my pressure / vacuum tool‘s handle just broke! The shaft seal has been replaced but a couple of seasons ago.
So decisions decisions .... I was kind of hoping this would be my last time in taking them off and putting them back on... I am getting too old and they are heavy!!
