Volvo Penta ms2
Margarine tub
New Member
17 Jan 2022
Hello. I have a Penta ms2 that has got a lot of corrosion around the coolant output. Looks like the o ring went ages ago and corroded all around the pipe. Coolant pipe was also completely blocked. Gessing the coolant pipe has an internal leak also. I need to replace ideally if not repair the bearing housing and internal coolant pipe. The pipe is not an issue I can find that part. The bearing housing I cant find and am unsure of the best way to remove it. Has anyone got any advise/spare parts or whole unit?
I thought as much in terms of availability. I removed the six bolts. Should it just lift off after that?
ITYWF the manual ( read it) suggests tapping it with a soft faced mallet.
Probably after all this time it will need a "bit of persuasion"
