Wandering Star
Does anyone have the correct part number for the rubber impeller for the above engine? I've tried to find the number on the internet but get conflicting results!
Thanks.
Thanks.
Thanks for this info Vic, all I know is the engine is original to the boat which was built in 1979. There are no markings on the pump to identify which impeller will fit. The impeller Steve_N has offered me looks correct, at least visually so I'm going to take up his generous offer and see if it fits. Thanks for your help.
There are only 3 things you need to specify. No of vanes, depth of impeller, overall diameter and fixing type to shaft. (4 things). You can ask a potential supplier before buying.
Just wanted to say a public thank you to Steve, the impeller arrived today and looks to be the correct part, he also included the front cover gasket of the pump too!875583 says MD7A on it.
P.S. you're welcome to this one should you care to send me an SAE.
