scottie
Perhaps referring to MD6/7 and rotary pumps etc will only add confusion IMHOIf you want to work out which is which and it is confusing here are a few manuals to check P/N s![]()
http://www.madlenkapluje.cz/attachment/HISTORIE/Volvo_MD1-D1-MD2-D2.pdf
http://capkarate.free.fr/divers/documentation/Moteurs Inbooard/VOLVO/MD2B/MD2B ViewFile.pdf
http://www.boatservicehaarlem.nl/volvo_md5wm.pdf
Volvo Penta Md6a Md7a Workshop Manua
https://www.maritimepropulsion.com/files/pdf/1001252
The earlier engines had cam operated fuel pumps all to the same design however the plungers and barrels might vary as different amounts of fuel required to suite the different powers and normally this would be achieved by varying the plunger/bore diameter. However as these pumps were also used in Yanmar, Bukh, Beta and others there may be commonality and Diesel Injection companies should be able to help here as they would have CAV and Bosch information regarding what went where.
Later engines had rotary fuel pumps on the exhaust side of the crankcase and these could be a problem as although Injection specialists can service and calibrate them they can not replace any internals unless a Picker can find some hidden in a barn.
