BruceK
Bruce, looks like a plan, drill it out both sides of the ram hole to basically cut the end cap in half ?
have you done this b4 ?
No, it was my plan of action and I put it to the board in this thread http://www.ybw.com/forums/showthread.php?511772-Taking-time-off-to-work-on-the-boat.
My endcaps a very corroded, it may not be necessary for you to collapse yours but once you've started and mangles up your end cap it may be you get out of jail card free. I was thinking of doing this as I have nothing to loose if the engines needed to come out according to the dealer to get the pins out. I can see why the dealer would say that as it is less labour time and easier for them. However I have time and patience and can disassemble my engines enough to reach the pins. I have invested in some serious grease guns and hammers to aid pin and ram removal. Now I am going to try just replace the entire rams on a prayer the pins can come out without transom shield removal and a slide hammer approach
