Volvo Penta D6 - IPS and engine oil change
Nick Epps
29 Apr 2022
Puerto Portals - Mallorca
Hi there, Is there a reason to maintain VP oil in both the IPS and the Engines, just been looking over the prices for 40 Ltrs in the engine and 32 Ltrs for the IPS drives. Your advice would be as always well received. Nick
Momac
7 Feb 2008
UK
The owners manual indicates the following.
In practice vds-3 engine oil will probably be required to also achieve the API requirement . Shell Rimula R4X 15W-40 achieves the requirements and is the engine oil I prefer to use .
But this complies
or this
The gear oil is perhaps a more sensitive topic so I will steer clear of that .
Momac
7 Feb 2008
UK
The gear oil is supposed to be fully synthetic 75w90 - 32 ltrs required....being quoted between 700 to 900 euros!!
Apparently the VP gear oil may include some special additives.
But fully synthetic GL4/GL5 gear oil isn't excessively expensive. Example as follows.
madabouttheboat
20 Jan 2005
UK, but for Covid it's England
I am normally a big advocate for using alternative VDS oil in Volvo engines, and alternative GL5 oil in drives, but when it comes to IPS (and also the new DPI drives) which use clutch packs I am not so sure. I have seen the size of the bill to repair an IPS drive with burnt out clutch packs and it was eye watering.
Momac
7 Feb 2008
UK
I simply point out the cost difference and the understanding that the VP oil may include some special additives.
As you say it would be a risk to use alternative gear oil in an IPS drive.
Portofino
10 Apr 2011
Boat- Western Med
But this complies
or this
This is just a boggo old school mineral oil ! .
Its VDS 3 , sure but with a D 6 or other IPS , modern robotised manufacturer , meaning tight tolerance of metals moving parts in contact , high speed rpm wise compared to a bigger displacement arguably potentially weak cooling ( As all boats are compared to road ) so running hotter than a Eddie Stobart truck chugging up / down a U.K. motorway …….wouldn’t you be kinder giving them full synthetic or at least semi syn ?
It just the load and high rpm being lower displacement to mitigate the extra omph the IPS reckons to give over trad larger displacement shafts .
Your pistons are traveling further faster than mine @ 1750 rpm all day with 32 - 35 L of synthetic sloshing about .
IPS Gear oil .
If you don’t mind I will stay out of that debate and if I ever return to outdrives or IPS pod use a genuine VP tech set up along with there ( ok expensive) parts and fluids . You gotta factor the maintenance, full costs in and keep an eye on residuals and the value of FVolvo SH at offload time .
When I sold my meagre expense wise by comparison DPG outdrive boat , the full VP SH made it easy .A lotus franchise guy snapped it up , he saw the VP SH file .There’s no more diligence he could have done .
We need real world experience of folks offloading IPS ……what buyers actually look deep into .Does lack of genuine lubricants in the pods put them off kill the deal ?How mech savvy are todays dry fingered key board only blokes coming through??
The 3 folks I know with IPS in sub 15 M boats always used a VP agent = lubricants on time as well .
Momac
7 Feb 2008
UK
That's what the VP spec says may be used.
PS but yes semi synthetic or synthetic engine oil may be used and is not necessarily different in price to mineral oil.
