Popski
First my apologies for this post as I know there are many on the forum but I just can’t see an answer to my problem. Which is:-
When I start the engine and check the fuel level I invariably get only ——— in the 2.5” display and the analog guage shows 0% even though I know there is ver 100 litres in the tank. Maybe after a few minutes the display will read 0% then 99% then 70% and settle. Once underway I get ——— again and that remains the same until I next take the boat out. I have checked the sender and the resistance levels appear to be in tolerance 0 - 180oms (+-10%). The connections to the sender and the sensor on the engine appear good. So I have attempted to calibrate the tank taking out the sender setting the float to 0% going through an empty tank cal. Pressing ok on the mfd then setting the float to 100% and again doing a full tank cal. Putting everything back and starting up all appears good right up until I get the boat out on the plane and the display is showing ——— again. So I’m stumped. Could this be a software issue and is it likely I’m going to require a voida to solve this proble. Any suggestions would be very helpful.
