Volvo Penta D12D-A swapping crankshaft ventilation filters
KajLehtinen
6 Dec 2003
Sweden, Stockholm
www.sealine.nu
Hi!
I guess its a question for one of the VP guys over here, is it possible to swap the crankshaft ventilation filters on a D12A-675 without removing the bracket that holds the main airfilter?
Seems to be 1 cm of clearance ontop of the crankshaft ventilation filter to the bracket above.
/Kaj
Hi!
/Kaj
Undo the two bolts that hold the air filter housing , you may have to remove the air filter housing on the port engine anyway to change the element then remove the CCFilters , you can also change the heat exchanger anode .
