larson250
Over the weekend the engine has been coughing and spluttering a bit especially when starting from cold.
On investigating the problem I found that one of the terminals had broken off the auto choke.
So hopefully I can cure the problem, however while doing this and a general service, I want to check the timing.
My only problem is, the manual I downloaded says "Authorised Dealer Service Only".
My questions are :-
Is the timing likely to "slip"?
Why is it not published?
I have a Clymer manual for an older GM, V6, volvo AQ series etc. that states the timing at 8 degrees BTDC.
Is this going to be the same?
Any info greatly received,
Dean
My questions are :-
Dean
