Volvo Penta 2003 raw water cooling questions
At see
New Member
4 Jun 2022
I am a newbie with a small motor boat (a 22' Steber "Persuader") fitted with a raw water cooled Volvo Penta 2003 and a sail drive. It think the date of inception is about 1986. It is a tidy little boat, if somewhat eccentric.
I have read with interest, verging on fascination, the very informative and perceptive posts about the raw water cooling system on Volvo Penta 2000 series and in particular 2003. I think that I have it cracked as to how it is intended to work.
I had mine scream "overheating" at me the other day. The pipe from the thermostat dome to the exhaust mixer was very hot. Backing off revs settled everything down. Water was blowing and not particularly hot. No steam was blowing.
I assumed a blockage in the water distribution pipe was somehow involved, because. first, the water pipe at the back of the block to the exhaust mixer was cold and did not become hot until the motor was off. and, second, the very hot external pipe from the thermostat dome to the exhaust mixer, which seemed to suggest a lot of work in that area.
First question: Does the bypass pipe from the end of the distribution pipe to the exhaust mixer ordinarily stay cold/cool in operation, before, or after, the thermostat opens?
As an aspect of that question, I am puzzled as to where the water fed into the distribution pipe goes once it is sprayed onto the injectors/cylinders if the thermostat is closed until 60 degrees is achieved and the second pipe is opened, and that water is not apparently going out the bypass pipe at the end of the block (which is remaining cool). Is this issue all in my head?
I disconnected the water feed pipe/port connection to the block and the bypass pipe from the block to the exhaust mixer and put a probe through the water distribution pipe (a Russian, Belarus tractor, dip stick...but that is another story) to check for a blockage. No apparent significant blockage. I blew into all the ports up to and including the exhaust mixer and got no apparent resistance. I have not yet used vinegar, or whatever, treated the distribution pipe to clean the holes in it, if they are blocked. That doesn't appear likely given that the motor is blowing water from start and the thermostat to exhaust mixer pipe remains cool for some time and then heats up, which, I assume, shows the thermostat is working in a conventional way, as is any earlier cooling mechanism (ie the distribution pipe).
Then I opened the drain valve at the bottom back of the block and got... nothing. It was literally dry on being removed. After I removed it I probed inside. Viscous muddy goop to an unknown depth! So the next stage step is to address removing the goop.
Second question: I assume that removing the goop adjacent to the valve is just a step towards opening the water cooling galleries in the block that are presently blocked or, at best, not functioning optimally. Can a "bottom up" solution work, ie just cleaning out the bottom chamber as aggressively as possible, or is a top down approach also needed, ie coming in through the distribution pipe and/or the thermostat port with some chemical weapon against goop.
Third question: can anyone identify where there is a diagram of where the water galleries are in a Penta block? That may give some clues as to how to probe mechanically or chemically.
I appreciate that anyhting to do with a Penta is a mixture of serious engineering and chemistry mixed with pure magic, but any thoughts would be appreciated.
Cheers,
At see
AS, Welcome to the forum :)
We also have a VP 2003 from 1988. Last winter I removed the pipes which lead to and from the flute pipe and saw that the inside wasn't too bad, but cleaned it a bit with a 6mm threaded rod about 1m in length. I then drained the block, removed the anode and thermostat and filled the block with diluted brick cleaner. As expected it bubbled away nicely but the colour of the fluid in the thermostat housing was a dark green / black colour :eek:. Topped it up a few times and then assembled the engine less thermostat and anode before running the engine in gear for 30 minutes. Lots of white stuff dissolved stuff came out of the exhaust. Refitted a new anode and the old thermostat and again ran for an hour in gear. Now this is quite aggressive treatment, so its your choice if you go down this route. VP used to sell a slightly weaker cleaner to do the same thing. Biodegradable Marine Descaler & Cleaners - RYDLYME Marine
I have previously had to replace the thermostat. Its a mix of metals running in hot salt water and ours had pretty much dissolved. Fitting a new one made a huge difference.
Recently whilst checking the gearbox DB hex mod I cam across this. Its the 16mm raw water pipe that goes from the gearbox to the water pump the missing bit of concretion was inside the copper pipe that joined. I replaced the flexible pipe which was getting on a bit and it pumps much better. The pipe connections to the gearbox also had some concretion, again cleaned the accessible bits out.
Btw, have you checked the VP 200x spline issue with these engines?
Not a bad engine and worth maintaining with lots of TLC as the engine itself is quite robust and since VP sold a shed full of them, lots of after market spares available from the likes of Parts 4 Engines etc.
Thank you for the greeting and thoughts.
I was thinking of starting with something gentler as a chemical approach and working up as needed.
As to mechanical tools, rummaging through the house I found a slim old woodworking auger (from brace and bit days) which should draw gunk out the valve hole while slowly boring into the deposit as a whole, until I strike water. With water struck a chemical dose passed down through the gunk from above, either thermostat or distribution pipe or both, should start to dissolve/break it up and accelerate extraction out the valve hole or more radically the exhaust itself..
I also have been lent a flexible pipe cleaning snake with a claw on the end. While hopelessly unwieldy, it may be a good exploratory device.
The peril with all of this mechanical work seems to me to be the risk of damaging the thread on the inside of the port into the block which engages with the valve or its holder. That risk seems to be the best argument for a chemical based approach, if it is not so robust as to damage the block as a whole or gaskets. So, proceed with care.
Running without the thermostat was something I had been considering. That seems the best idea if you are using the sea water pump to recirculate any dosing through the engine and then capture the result from the exhaust pipe by undoing it before it gets to the water lock and drop it in a bucket that is also feeding the pump. Lots of ventilation needed (but it is easier than a bucket and pump under the external exhaust outlet).
I have not yet checked the pipe from the sea cock on the sail drive to the pump. but I suspect it is pretty OK just from the amount of water that is being spilled from the exhaust. However, I will check it and replace any old hoses.
The gunk pile in my motor must be absorbing over a third of the water capacity of the system, and probably blocking all the galleries or some of them, so it is a, or the, villain, whatever else is happening.
cheers AS
when running yours, does the copper by-pass pipe from the back of the block to the exhaust mixer stay cold and only the pipe from the thermostat dome to the exhaust mixer get hot?
Not sure, never really tested it. Also our copper pipe from the thermostat housing goes to the calorifier first and the return then empties into the exhaust pipe housing on top of the block so lots of heat removed this way.
Would you not expect the pipe between the thermostat housing and the exhaust elbow to become hot when the thermostat opens (60C) and the pipe from the back of the cylinder head to the exhaust elbow to remain cool eventually becoming no more than warm .
Note that if you remove the distribution pipe it must be correctly orientated when refitted, as shown in the workshop manual
wow!! today I removed the thermostat cover to check on the thermostat, a reasonable thought!! inside was, as depicted in the photo attached. No thermostat and a really messy looking port into the block. The pipe from the dome to the exhaust mixer was good, as was the elbow itself and the dome of the housing was very clean. I cleaned up the junk that looked like junk in the block, but I have no idea what the inside the the housing in the block should look like and whether, as it is now, or as I can get it to be, it will take the thermostat.
on the crud in the bottom of the block front, the auger drilled up through this viscous mess until suddenly clean clear water flowed. the problem with this result is the bed of mud is still there, it just has a hole in it. That said, at least I can drain the water jacket and flush it. I am flushing with Barnacle Buster as a starter. I look forward to setting speed records with this engine after these treatments. On a run this afternoon, at high revs and speed, no overheating alarms. A win already.
yes. I would. What was interesting me was the other pipe, from the back of the distribution pipe to the exhaust mixer, it stays cold, which is fine if it is only taking raw water surplus and discharging it. However if it is receiving water that has done cooling it ought to get warm. I assume it gets warm after the engine is off because the hot water in the thermostat pipe is mixing in the exhaust elbow and seeps down into the pipe to the block.
thank you VYV-cox. mine is raw water cooled system. bog ordinary. what I am missing is some idea what the inside of the block where the thermostat ordinarily sits ought to look like, so I don't start hacking off something essential in that space. if I can get to what it ought look like, then I can contemplate a thermostat being reinstated and some semblance of the intended operation of the cooling system achieved. I cannot find a photo or diagram of the inside of the block where the thermostat sits. If anyone has taken such a photo of their engine is pristine (or close to it) condition, it would be immensely useful.
The photos tell you what is hot. Thought that was what you wanted to know.
Hi Pete, could you provide the diameter of the distribution pipe please ? I nota a 6mm threaded rod went inside it so thinking 8mm ? Asking for the purposes of using a drift to help it out of its current stuch position.
Answering my own question directly above. . . while I don't have the exact measurement, since the pipe remains in the engine, I did manage to push out 15mm of the pipe hammering gently on a socket from the front of the engine. The socket diameter, at 12mm exceeded the pipe's ID but did not protrude beyond the Outer diameter, so a perfect match. To complete the pipe's removal I've bought a 12mm brass rod x 300mm as I understand the tube can require encouraging out along it's entire length. To assist with removal use an inverted air-duster can, squirting the contents into the pipe, cooling and contracting it in the process - a great tip courtesy Sailing Britaly
